Ceiling fan light problem,
Old 03-02-17, 09:12 AM
T
I'm confused.
I wanted to boost the light output from my ceiling fan.
It has two lights, rated for 60W maximum.
When I put in 14W LED (100W replacements) and switch the unit on - the lights flash on for one instant, then turn off. ???
I can remove either bulb, then the remaining one works fine.
Aren't fixtures rated by actual wattage instead of lumen output?
What am I missing?
Old 03-02-17, 04:17 PM
Received 3,983 Upvotes on 3,575 Posts
In most ceiling fans you cannot use LED or CFL bulbs.
Most will specifically state "incandescent lamps only".
In many fans.... using a non incandescent bulb will immediately blow the dimmer section.
Old 03-02-17, 06:17 PM
T
Thanks
Hi:
But everything works fine with an LED in one side and either an incandescent or cfl in the opposite side.
The problem only arises when I try two LED's at the same time.
Does this make sense?
