Recessed lighting IC or Non-IC
Old 03-19-17, 11:11 AM
R
Is it possible to tell if recessed lighting is IC or Non-IC just by looking at it? It have read all the stickers in the can and it does not say. I have tried to figure it out myself, but all the info I found in the can ended up a dead end. I've taken some pics and attached them. Anyone here have an idea? Thanks for any info you might have.
Name:  full view1.jpg
Name:  full view2.jpg
Name:  Housing model.jpg
Name:  UL label.jpg
Old 03-19-17, 11:40 AM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
I am leaning towards to non-IC but please post a picture of the last label. (circled in red)
Name:  can label.png
Why are you asking? Are you planning to add more insulation?
Old 03-19-17, 12:03 PM
T
It's not IC rated. The sticker that Tolyn requested a closeup of is where it would say: "Type IC". Also, IC rated fixtures do not have holes/slots in them.
Old 03-19-17, 12:46 PM
R
Tolyn, the label says, in both English and Spanish:
Caution: Risk of Fire. Use with "Commercial Electric" Trims only
for each lamp type and wattage indicated.
Notice: Inherently protected. Blinking light of the thermally protected
luminaire may indicate overheating.
Yes, I am thinking of more insulation. If I replace the cans with IC cans, can I just lay the batt insulation over them? Or is there a special way you are supposed to insulate around IC cans?
Old 03-19-17, 01:15 PM
T
You have two options.. You can either replace the cans with IC-rated or install a "cap" over the top of the can. In either case, if you are using batts, you cut a hole in the cavity batt for the can/cap to fit snugly through, then if you aren't doing another cross layer, put another batt square on top.
