Rotary LED dimmer
Old 04-20-17, 02:14 PM
C
Rotary LED dimmer
Does anyone make a rotary dimmer that works with LED bulbs? I haven't been able to find one. Thanks
Old 04-20-17, 03:10 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Why do you want a rotary dimmer?
Old 04-20-17, 03:19 PM
Received 4,119 Upvotes on 3,699 Posts
There was a Leviton one that was supposed to work with LED's and it didn't.
So.... no... I don't know of any round style dimmers that will work reliably with LED bulbs.
Old 04-20-17, 04:51 PM
C
Larry, I was hoping to get a rotary dimmer because the switch is part of a three-switch gang. If I can't get a rotary dimmer I'll have to replace the other two non-dimmer switches with decoras.
Old 04-20-17, 05:01 PM
chandler's Avatar
Why can't you use a decora style dimmer and still keep your standard switches and just change cover plates? Or am I missing something? Leviton Decora 3-Gang Midway 2-Toggle Combination Nylon Wall Plate, White-R52-PJ226-00W - The Home Depot
Or use a dimmer that fits a normal switch plate. http://www.homedepot.com/p/Lutron-To...H-WH/202746671
Old 04-20-17, 05:21 PM
C
Ah! I wasn't aware of that switch plate and dimmer. Will definitely look for them. Thank you very much!
