Replacing recessed lighting
Old 05-20-17, 04:42 PM
Received 1 Upvote on 1 Post
I have a bunch of recessed lights in my house and looking to replace them with LEDs and possibly new trim.
My first question is, why go with a retrofit LED kit like this:
Cree TW Series 65W Equivalent Soft White (2700K) 6 in. Dimmable LED Retrofit Recessed Downlight-DRDL6-06227009-12DE26-1C100 - The Home Depot
as opposed to just replacing the bulb with a LED bulb? Is it for the looks? I'm thinking of going with the retrofit just for the looks. However the downside seems to be if one goes out, what if the kit is no longer available? What are the other considerations?
Also the cans I am installing them on... it has one big clip at the top. The type I am familiar with has the clips on the baffle trim. However the retrofit kit I linked to above looks like it can handle any type, I don't need to use the clips in the can. Other retrofit kits such as this:
Halo 5 in. and 6 in. 3000K Matte White Recessed LED Retrofit Baffle-Trim Module 80 CRI-RL560WH-R - The Home Depot
have the clips I am used to... I can't use these right?
Any advise? I replaced a couple of the cans with Sylvania LED bulbs from lowes:
https://www.lowes.com/pd/SYLVANIA-65...-Bulb/50225173
But I wasn't too impressed. Wasn't instant on!!
Thanks. See attached pics of my stuff.
Old 05-20-17, 05:55 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Using the stand alone bulbs, you will need to use your current trims. At least when you buy the LED unit, it is all together. The second one you mentioned won't work in your cans. The first one is held in via friction of the fingers, so they will possibly work fine. I would buy one and try it to see if it is what you want in lighting.
