Ceiling Fan / Down Rod Assembly...
Old 05-29-17, 09:43 AM
NorPlan1's Avatar
Have a Ceiling Fan from Hampton Bay sole owened by Home Depot.. The objective is to mount the Ceiling Fan flush to the ceiling.. It indicates on the Box of being able to do so.. Tried asking Home Depot to No Avail.. The problem is the Ball / Downrod Assembly, was told I could loosen the screw holding the rubber ball at the top slide the ball down the rod and screw back against the Rod.. There's only one hole drilled at the top holding the ball.. There is only one hole at the bottom of the rod for the Pin that slides in to hold the main fan body in place.. Tried explaining to the Home Dept people that just screwing the Screw against the Rod isn't secure, how is that going to hold the business end ?? Can the Fan actually be mounted flush to the Ceiling ?? Help Appreciated, Cheers Thanks
Old 05-29-17, 10:10 AM
Received 3,601 Upvotes on 3,229 Posts
A link to or the model number of the fan would be helpful.
Old 05-29-17, 11:13 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
HERE IS THE SUPPORT SITE FOR Hampton Bay will need model #
Hampton Bay Customer Support -Troubleshooting & FAQ | The Home Depot
Old 05-29-17, 11:52 AM
No.... you don't use the long rod at all. You replace it with a supplied shorter one OR the canopy attaches directly to the motor unit with no rod.
Old 05-29-17, 03:33 PM
NorPlan1's Avatar
You replace with Supplied Shorter One OR The Canopy attaches directly to the motor unit with no rod
The only recourse is a Shorter Downrod if such can be had as the only way the Main Body can be attached is thru the Downrod.. Cheers Thanks for The Comebacks Anyway..
Old 05-29-17, 03:42 PM
Ok.... if you say so.
home depot/howto/servlet
