Ceiling fan light fixture only works on high speed
Old 08-05-17, 06:14 PM
F
Hello all,
I had a new Hunter flush mount ceiling fan with a light fixture installed last week by a journeyman electrician. He installed a new box that was fan rated but the problem is that the light won't work unless the fan is on high speed. I have a single wall switch that operates both the fan and the light and the fixture itself has 2 chains that operate the fan and light separately. He also installed a similar Hunter fixture in another bedroom that doesn't exhibit this problem. He's at a loss to figure out what is going on. Any ideas?
Thanks for any help.
Old 08-05-17, 10:25 PM
Received 1,476 Votes on 1,364 Posts
Welcome to the forums.
Knowing Hunter fans.... either the plug and socket where the switches are located is not plugged in solidly or it's forced in backwards.
You can remove the three screws that hold the light up and the switch housing to the motor unit to check it out without removing the entire fan from the ceiling.
Old 08-07-17, 02:05 PM
F
Thanks for the response. I'll pass it along to my electrician.
