Replacement for wall-mounted bathroom fan
Old 09-02-17, 10:22 AM
AuDIYer's Avatar
Hi all. I have a basement bathroom in which the bathroom fan is mounted in the wall and I'm stumped on finding a replacement. See attached photos - with cover and without cover showing a cylinder-type fan mounted within the exhaust pipe. The fan is old and has recently gotten a lot louder, so I'm looking to replace it with a new quieter model. The problem is I can't find a replacement. I showed the pictures to the local Home Depot and Lowes staff and they were stumped as well. I can't find one online either. Any idea where I can find such a replacement fan? Thanks!
Old 09-02-17, 10:44 AM
Received 3,748 Upvotes on 3,361 Posts
Welcome to the forums.
It's possible and may be easier to just replace the fan motor.
What you are looking for is a thru+the+wall+exhaust
Old 09-02-17, 10:47 AM
AuDIYer's Avatar
Thanks Pete! I guess I wasn't searching using the correct name. This is very helpful.
Old 09-02-17, 11:28 AM
Some of the thru the wall fans are designed for kitchens and move higher air volumes then a bathroom fan might.
This one uses a twist lock motor mount and it may fit into your housing.
Broan 270 CFM Through-the-Wall Exhaust Fan-508 - The Home Depot
