Bathroom light fixture
Old 10-14-17, 06:42 AM
E
Just had a contractor in to fix upstairs bath tub/ plumbing. Next day we find a water leak. The light was working before we found the water leak. Now turn the light switch on, the light flicks on then immediately off. The switch is still in the on position. Light is off. Could water be causing a problem or would it be something else. I think they may have removed the fixture partially when they painted the room. Not sure.
Old 10-14-17, 11:16 AM
ray2047's Avatar
Check the connections first. Redo any wire nuts. If the switch is back stabbed move the wires to the screws.
