Replaced one switch for two light fixtures
Old 12-11-17, 03:44 PM
I replaced a toggle (off/on) single switch that controls both the vanity lights and a ceiling light in my bathroom. However, only the ceiling light turns on. Is it possible while attaching the wires to the new switch, the wire to the vanity fixture came off? Could there be another explanation?
Old 12-11-17, 05:38 PM
Received 1,114 Votes on 1,034 Posts
Welcome to the forums.
You are asking us to guess. Could a wire have broken off..... yes.
How many wires were on the switch ?
Old 12-15-17, 01:42 PM
Besides the ground, there was a red wire that was connected at its terminal end to the switch, and a black wire that was connected between it's terminal ends. See attachment.
Old 12-15-17, 02:24 PM
If that's the old switch..... it is a 3 way switch.
Is there another switch that works with that one ?
Is that the original wiring in that picture ?
Old 12-20-17, 06:19 AM
That's the picture I took before I did anything. There is no other switch. Plus , it has an on/off marking, indicating a single pole switch.
Old 12-20-17, 12:00 PM
I got it fixed. I took the fixture off and it seemed all the wires were connected. Then I took another look at the switch. I reinserted a wire, which I thought was a ground wire, into a hole at the back of the switch. Both light fixtures come on. Perhaps that wire is a hot wire, and not a ground.
Old 12-20-17, 05:07 PM
That wire pushed in to the back is actually connected to the red screw terminal. Using both is a recipe for problems. That pushed in black wire and the red wire should be connected together along with a short piece of wire to connect the splice to where the red wire was on the switch.
Old 12-21-17, 09:05 AM
Pete, thanks for the heads up. But, that's how I found it before I did anything. See the picture. This is the first time I replaced this switch. So, whoever wired this when the house was built did it wrong?
