courtesy light in car
hey everyone,
recently I decided to change all my lights in the car to white LED and I have in my car Chrysler 200S 2016 two courtesy lights 1" diameter in the back with yellow led light and I couldn't find anywhere a replacement for it so I was wondering if there is an option to just buy white led and just solder it on the existing lights instead of the old ones and I wanted to see if anyone knows if it will work or if they had a similar experience in it, thank you!
Welcome to the forums.
If you use raw LED's..... you need to use a dropping resistor for 12v use.
What is the part number on that bulb ?
As far as I know.... every bulb has an LED equivalent now.
Hey, thanks for the reply I attached an images of the light and there is a number but I have no idea what to do with it is there a site where you can search it by model #?
https://www.dropbox.com/sh/hlnponbf0...FEFCb4Iua?dl=0
Oh, there would be plenty of white replacements for that. Cheap also...like $.30 each + shipping. It's probably got all the circuitry necessary on the board so a simple swap would do it once you know size and style. Do you know how to solder and unsolder surface mount devices? If not, this isn't a good place to learn.
many online have cheap upgrade kits... Call a few and see whats available...
2015-up Chrysler 200 Interior LED Lights Package
I can solder no problem I was just worried if needed anything else and all those kits online are for the regular 200 which has dome light and mine the 200S has moonroof so there are two courtesy lights instead of the dome and no one seems to provide that.
what is the name for the LED just the component, and how can i determine the strength that this circuit can hold (lumens)
thanks you
thanks you
