Dimmer switch on 3 way?
Received 0 Votes
I have recessed lighting in my basement. I have 3 light switches that control them. One in the garage, one at the walk out basement door and one at the top of the stairs. I want to put a dimmer switch On the one at the top of the stairs. Is that possible? Can I just replace the current light switch with a 3 way dimmer?
Yes and no.
FYI.... that's called a 4 way system. A 4 way system is 2) 3 way switches and then additional 4 way switches.
Some dimmers claim to work with existing switches. The claim relies on the wiring being set up a certain way.
I no longer will install any single 3 way dimmers. I install a dimmer and then use additional slave dimmers. This method always works. The wiring will not be plug and play. Wire connections will need to be changed.
Depending on the dimmer.... that is correct. Some dimmers need to be at the line end and some at the load end.
With a dedicated dimmer and its slave remotes.... the dimmer can be at either three way switch location.
