help with installing 6" remodel cans in between joists with little width space
Hi I'm installing 6 inch remodel recessed cans in my ceiling but I guess being a older house the joist space is not as wide as most homes. I measured about 9.5 inches width and some that are 8 inches wide that I want to use. The cans will fit in the openings and probably the 9.5 inch space joists I could have enough room to fasten the cans clips to the drywall but the 8 inch wide joists probably won't allow me to fasten the 2 clips that is facing the joists (tight fit) Would it be secure enough if I fasten only 2 of the clips to the drywall ceiling that are away from the joists? and if not I could I also screw a couple of wood screws in the opening where the clips go to the joist to secure it? To me it looks like it could work but I wanted to get another opinion before I proceed. Thanks in advance.
Sometimes the placement of rafters/joists are not ideal.
Replaced all our ceiling lights with cans anf down one hallway I actually moved a rafter over 3" just to get the can in the center.
As noted smaller cans will help or if you have access from the top you can attach the can to a piece of plywood and glue that to the drywall and not even use the clips.
