Need to Remove Old Battery from Tiffany Table Lamp
Received 0 Votes
Please let me know if another thread would be better to use. My wife found an inexpensive Tiffany-like Table Lamp that she likes at a thrift store. It works when plugged in, has a built-in rechargeable battery that's dead, has brick wall charger, has a rotating and dimmer/on-off switch. No name on the lamp. May not be necessary, but it seems to me that it's likely wise to remove the old rechargeable battery in the lamp's base which no longer stores power. I'm handy with tools, but circuits are not in my knowledge base. Need some guidance since she wants to keep it but doesn't care about having it portable with battery power.
Solution may be simple, like unplugging the battery, wrapping the connectors, and adding some weight in the base so it will stand. Don't want to mess up the circuit board. I'll include photos. Thanks in advance for any suggestions!
You can probably just remove the connectors from the batter and put a piece of electrical tape over each connector. I suspect that it will continue to light. if not, you buy a replacement battery for $15-$20.
- Peter
- Peter
