Recessed lighting with Ceiling Joist
Old 07-21-18, 02:09 PM
R
We're adding recessed lighting in the kitchen and have discovered a ceiling joist where we wanted to place a light. I've attached a picture of it. The idea came up to use a flat panel LED light? One like this https://www.amazon.com/gp/product/B01ND1KCGP/.
Is it safe to install that directly under a ceiling joist? It might need a small notch cut out of the joist. Would that be safe?
Has anyone put flat panel LED lights in their kitchen? How's the light coverage and how do they look?
Old 07-21-18, 03:46 PM
Received 1,176 Votes on 1,090 Posts
Welcome to the forums.
Are you sure that is a ceiling joist. It's not running parallel to either wall. It may be a roof rafter.
Old 07-21-18, 08:30 PM
Tolyn Ironhand's Avatar
Received 220 Votes on 194 Posts
I have used those LED lights with good results. Brightness was similar to an incandescent of similar size. I do not recall exactly how thin they are but I purchased mine from the big orange store. You may want to check them out in person before buying them.
Old 07-22-18, 08:21 PM
R
After a closer look. It looks like may be a roof rafter. Any suggestions on a solution?
Old 07-22-18, 08:30 PM
I wouldn't cut or notch it. Move the light or use on of those shallow LED types.
