Wiring fluorescent lights and code
Old 08-30-18, 01:28 PM
Received 2 Upvotes on 1 Post
I'm in a commercial office building where I need to split some fluorescent lights to get them on a different switch. I have several questions, on a 15 amp breaker how many fixtures can I safely put on that breaker? My second question is that I have several metal clad cables running to one fixture. Do I need to put all of that into a junction handy box at the site of the fixture and can I leave that box on top of fixture or do I need to mount it? I dont know code but I can be taught.
Old 08-30-18, 02:45 PM
ray2047's Avatar
For reasons of liability only a licensed electrician should do the work.
Old 08-30-18, 11:29 PM
Great so I guess I could spend a small fortune to pay an electrician to come where one little light as opposed to someone telling me what might could be done and save myself thousands of dollars.
Old 08-30-18, 11:48 PM
Received 1,182 Upvotes on 1,140 Posts
Are you insured for the fire which could result from your work?
Old 09-01-18, 08:04 AM
CasualJoe's Avatar
Received 172 Upvotes on 155 Posts
The questions tell me you are not qualified to do the work.
Old 09-01-18, 12:40 PM
Tolyn Ironhand's Avatar
Received 662 Upvotes on 562 Posts
A small job like that shouldn't cost thousands of dollars. Many shops can be found charging $100-$150 per hour plus material. I also suspect the building owner will not want you doing electrical work in their building.
