LEDs going slightly over wattage
Old 09-28-18, 06:17 AM
R
I just had someone install a new Harbor Breeze ceiling fan and I went to put in some LEDs that I had that were 800 lumens and 8.5W. The ones that came with the fan were 6.5W and 600 lumens. There was a warning not to exceed 6.5W.
So my question is can 2W really make a difference? Is that a fire hazard if I put in the 8.5W? What does the community think? Thanks
Old 09-28-18, 07:50 AM
P
Received 619 Votes on 572 Posts
Are you certain the fan said 6.5 maximum or does it say 65 watts maximum? I am accustomed to seeing fixtures that have a 60 or 100 watt maximum but I've never seen anything specify a maximum as low as six and a half watts.
Old 09-28-18, 11:37 AM
R
Yes I'm certain it was 6.5w since it says the lights are for LEDs
Old 09-28-18, 03:19 PM
Received 94 Votes on 83 Posts
Then I would say that's the max you should use.
Old 09-28-18, 04:23 PM
B
Received 87 Votes on 76 Posts
Additional 2 watts is a 33 percent increase. Do not exceed the manufacturers rating. Buy another fan/light that allows for higher wattage bulbs if that is what you want.
Old 09-28-18, 06:47 PM
B
Received 37 Votes on 34 Posts
How many bulbs in that fixture?
Are the bulbs fully enclosed?
I agree with the skeptical thought that the max is 6.5W.
Unless there is something special about those lights the extra 2 watts is insignificant. However, forum guidance will not allow me to recommend exceeding mfg guidance.
Check their web site and/or contact them to get their advice.
Bud
Old 09-28-18, 07:58 PM
6.5w is not much, I'd be looking for a different fixture,
Old 09-29-18, 05:59 PM
B
If the device is UL approved, any change that increases power is significant because it has not been tested. If not UL approved and you want to experiment, make sure you understand you homeowners policy. You may need to use it.
Old 09-30-18, 05:02 AM
Norm201's Avatar
Received 230 Votes on 205 Posts
Yea, I find it hard to believe that fan manufacturers are retooling and changing their design to only accept a light bulb at 6.5 watt ratting. LED's already use very little power and produce a lot less heat that an incandescent bulb. However, they do produce heat and should be vented to outside air. If in fact the fixture is rated for only 6.5 watts then the design factors are very close and I would not use anything higher.
Old 09-30-18, 05:21 AM
B
A guess here. I suspect the fixture was an import and strange labels are to be expected as the translation often get as little care as the making of the products. IMO, the light will handle much more than the 6.5 watts that is reported. If the fixture went through UL the testing people would have covered a wider range as they too would know that is ridiculous.
The op simply needs to make some calls and send some emails and, again my opinion, clear this confusion up.
For the record my employer sent many products off for UL approval and they were always accompanied by an engineer to discuss the application.
Bud
Old 09-30-18, 06:24 AM
R
thanks everyone for responding. I have to call the manufacturer monday. There are stickers on where you put the bulb that do say 6.5W max. HOWEVER in the manual it says use replacement bulbs no more than 60w max and it says use incandescent, cfl or LED.
To answer another question it is not enclosed the fixture. LEDs produce such little heat its hard to imagine 2 W doing anything. Maybe the sticker is wrong?
Old 09-30-18, 06:41 AM
B
Is there a "made in (?)" sticker there? Sounds like the 60w is correct, let us know.
Bud
Old 09-30-18, 08:37 AM
Norm201's Avatar
I'm betting the 6.5 watt is a mis-print.
Old 10-01-18, 06:28 AM
R
I called the company harbor breeze. They have no idea. Basically said I don't know why the sticker would be so different from the manual. A supervisor also said they didnt know.
Old 10-01-18, 07:15 AM
B
Why am I not surprised? You might be able to dig through the UL.COM link and find the test specifications, I looks and chickened out.
Make some notes about what you asked and what they said, names if you got any and save it. A reasonable assumption is the 6.5W label is a mistake. I know the super cautious approach would be to believe it but that is contrary to the experience everyone here should have.
You could also contact the place where you purchased it and ask for clarification.
Also keep that manual.
Bud
Old 10-01-18, 09:30 AM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
What is the Lowes item number?
I can guarantee the fan is Made in China, I haven't seen a new ceiling fan in the last 10 years that wasn't made in China. I also suspect that the true rating is 60 watts per socket maximum.
Old 10-01-18, 11:26 AM
R
Hi - The Lowes item No is 807432.
