Ceiling fan to light fixture wiring
Old 09-29-18, 12:55 PM
I am replacing a ceiling fan with a light fixture. Ceiling fan was on two wall switches ó one for the lights and one (knob) for the motor. When I took the fan down I had 4 sets of wires; black, white, ground, and a blue/red pair. The blue was attached to the fan, so I capped the red assuming it was for the motor. I wired up the new fixture and it will not work. I changed the bulbs so that is not the problem. Any suggestions on what I missed?
Old 09-29-18, 01:59 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
and a blue/red pair
Do you have cable or conduit? Are you sure the blue isn't from the fan wires not the house Wires? Blue would be unusual for residential wiring.What wires are at the switches?
Old 09-30-18, 07:57 AM
blue wire
Ia
I am in a new construction home, so I believe it is cable. Yes, the blue wire was attached to the fan unit and came off when I took down the fan.. I was left with the ground, black, white and red wires. I assumed I was to cap off the red wire, but when I look at the switch box, I have a ground wire connected to a screw, 2 red wires connected to the same screw, and a black wire connected to a screw. Any help is much appreciated!
Old 09-30-18, 09:19 AM
ray2047's Avatar
Isn't there a white wire (s).
Old 09-30-18, 09:44 AM
There is no white wire. There are 3 switches on the wall
plate. The first has no wiring attached to it... just a non-functional Luteon switch. The second is a dimmer switch that controlled the ceiling fan light and the third controlled the ceiling fan motor.
Old 09-30-18, 10:00 AM
I am thinking I need to hook up the red wire the fixture instead of leaving it capped. Just donít know if I should cap it with the black or white wire?
Old 09-30-18, 04:06 PM
Received 2,966 Votes on 2,676 Posts
You had four wires..... not pairs or sets of wires.
We understand white, black and ground. That signifies an NM type cable.
What is a blue/red pair ???
Is it one wire or two wires ?
It would make sense if it was red.
The light needs to be connected to white and red OR white and black.
The unused wire gets capped off.
Old 10-01-18, 03:03 AM
Sorry... It was one red and one blue. The blue was part of the ceiling fan unit. So I am left with 4 wires in the ceiling box. The new fixture has 3 wires. I am just not sure what to connect the red wire to. Black? White? Thank you....
