LED bulbs flash when lit
Old 12-01-18, 06:51 AM
C
I have just had a new fixture installed in my bathroom and am using LED bulbs in there for the first time. I'm concerned because when I turn the light on, there's a noticeable flash coming from the bulbs. I'm not seeing any flickering from the bulbs, just one flash when the lights go on. Should I be concerned about this? Is it the bulbs, incorrect wiring, a bad switch (the switch is almost 20 years old). I've got a call in to the guy who installed the fixture but I haven't heard back from him yet. Of course, I'm concerned about a spark starting a fire. Thanks.
Old 12-01-18, 07:00 AM
Tolyn Ironhand's Avatar
Received 877 Upvotes on 740 Posts
There is likely no issues with the bulbs and there is no danger of a fire. Is the switch a dimmer?
Old 12-01-18, 07:06 AM
C
Thanks for responding. It's a regular switch, not a dimmer.
Old 12-01-18, 07:47 AM
C
So I shouldn't worry about it?
Old 12-01-18, 07:52 AM
Received 3,951 Upvotes on 3,544 Posts
No..... nothing to worry about. Some LED's do that when starting up.
I don't think so. The flash is likely just them starting up.
Old 12-01-18, 08:17 AM
C
Thanks. You've eased my mind.
Old 12-01-18, 12:47 PM
B
Received 47 Upvotes on 43 Posts
If you have any different brand LEDs you could swap one out to see if it makes any difference.
Bud
