Got a spark when testing for live voltage at ceiling light.
Old 01-19-19, 01:21 PM
I was testing for live voltage at ceiling light fixture when changing light fitting. I just touched the live wire with manual live volt testing screw driver and got a big spark and circuit breaker tripped. Now the light wonít work but bulb is ok. I donít want to test for live voltage at source in case it sparks again. Any idea on why it would have sparked and what might have gone wrong
Old 01-19-19, 01:42 PM
Received 1,112 Votes on 1,032 Posts
Welcome to the forums.
Either your tester is shorted or your probe hit a live wire and ground or neutral.
Test your tester in a receptacle to make sure it's working properly.
Old 01-19-19, 01:48 PM
Thanks. Is it possible that I might have damaged the dimmer light switch
Old 01-19-19, 05:42 PM
Received 249 Votes on 219 Posts
It is very likely that the spark killed the dimmer.
Old 01-20-19, 06:25 AM
Geochurchi's Avatar
Received 73 Votes on 69 Posts
What is the voltage rating on that manual live voltage testing screw driver? Post a pic as I have never seen one for line voltage testing.
Geo
Old 01-20-19, 06:55 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need to spend $8-$15 on an analog (not digital) multimeter. Then you can do some serioue testing.
Old 01-20-19, 03:15 PM
A
Received 81 Votes on 75 Posts
Your hand slipped and the end of the screwdriver or probe touched two things instead of one. Or you pushed the wire instead of just touching it causing it in turn to touch something else. You might want to tape over all but the last 1/8 inch of the tip of the probe to cut down on such accidents in the future.
Looking carefully you might see burn marks or metal melting showing exactly where things touched that should not have.
Old 01-21-19, 10:50 AM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
Geo
I have one that I believe is rated at 600 volts and always loved it. I haven't used it regularly for 35 or more years. Can't remember the last time I saw one for sale.
