converting plug in lamp to battery
Old 01-26-19, 08:39 AM
W
hello I have a little accent lamp which uses a 0.5w LED night light bulb. If I wanted to power it with a 2000mah AAA battery instead of the current plug-in how long would the battery last before recharge?
Old 01-26-19, 11:28 AM
Received 4,106 Upvotes on 3,687 Posts
The LED would require closer to 3vDC to operate normally. You may be able to run it on two AAA batteries in series. Two AAA would last a long time between charges if the light was only used at night. Probably a month.... maybe more.
Old 01-26-19, 12:41 PM
W
Thanks - I usually keep it on continuously
Old 01-26-19, 12:49 PM
W
Also, would any 3v dc battery work?
Old 01-26-19, 12:52 PM
I would think so. You could try it on standard batteries first.
Keep in mind that regular batteries are 1.5v and rechargeables are 1.2v.
Old 01-26-19, 02:09 PM
P
Received 2,270 Upvotes on 2,022 Posts
If using a disposable battery you can run it down to completely dead. If using rechargeable batteries you will not be able to use the full capacity listed on the battery. I would use regular alkaline batteries and just toss them when dead.
