How to repair the loose electric socket
Old 07-03-19, 12:13 AM
B
The electric socket pops out from the wall..How do I fix it?
Old 07-03-19, 04:18 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Need more info, dose the outlet itself come out or the box ansd socket is loose? Picture would help.
How-to-insert-pictures.
Old 07-03-19, 04:52 AM
B
Added Picture
I have attached a picture to illustrate the problem. The electric socket pops out from the wall. It supposes to be aligned to the wall.
Old 07-03-19, 05:07 AM
P
Received 2,108 Upvotes on 1,887 Posts
The nails, screws or whatever holding your electrical box to the house's framing have broken or come loose. A proper way to fix it is to cut out the sheetrock or plaster around the outlet so you have access to the outside to re-attach it as it was designed to be mounted. The easier but not code approved method is to turn off the circuit breaker for that box. Remove the cover plate and outlets. Then drill a couple holes in the side of the box and screw it to the stud.
Old 07-03-19, 05:31 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, that whole arrangement looks MM, looks like 2 separate plates, remove the plates and post a pic of the box.
Geo
