PAR38 light fixture
Old 09-27-19, 03:04 PM
Received 1 Vote on 1 Post
PAR38 light fixture
I have an outside motion security light that uses two PAR38 bulbs. The lights suddenly stopped working (both bulbs) so I wonder if it's something wrong with the light fixture or the bulbs are bad.
I waved my hand over the light and I can see the tiny motion sensor light flash on and off so it is getting power.
I don't have another PAR38 bulb to test. I just wanted to test to make sure it's the bulb, can I screw in a standard A19 bulb to the fixture socket just for testing? Or is this a bad idea? Electrically they all should be compatible correct?
Old 09-27-19, 03:52 PM
Norm201's Avatar
Received 255 Votes on 229 Posts
if the base is the same then yes you can test with an ordinary light bulb. Most likely the fixture is going bad.
Old 09-27-19, 07:17 PM
Received 268 Votes on 232 Posts
You could screw par38 into a lamp to test it.
Old 09-28-19, 04:29 AM
A
Received 17 Votes on 17 Posts
If both bulbs stopped working at the same time I would say more than likely the fixture is to blame.
Is this an older fixture? Even some of the newer ones that are plastic are built cheap (like the $15.00 ones you find at the big box stores) and then tend to die over a short period of time.
