Does this look right, how can I tell?
Old 10-25-19, 10:59 AM
G
I just shorted a dimmer switch. Google took me here to a thread about using the proper wattage dimmer switch. I think that was my issue. The switch controls 5 incandescen bulbs. Can you have a look at this set up and make sure that there is nothing else I am missing? Based on recommendations here I think I will replace it with a regular light switch first to make sure Iíve got it right before burning out another expensive dimmer.
Old 10-25-19, 11:06 AM
Received 4,119 Upvotes on 3,699 Posts
Welcome to the forums.
You connected the dimmer to a short circuit.
The black from the dimmer goes to hot/line.
The red from the dimmer goes to load.
Nothing goes to neutral.
When you do future wiring..... pull the devices out and take pictures before disconnecting them.
Old 10-25-19, 11:27 AM
G
Thanks Pete! The dimmer stopped working, and when I pulled it out the box, one of the blacks from the original nob style dimmer pulled out of the wire nut before I could see which one it was. I wish I would have come here first!
