Motion Detector
Motion Detector
I recently changed out the bulbs in this outside motion light. I toggled to test and it only gives me flashing lights. I moved and tested all switches and reset to my desires settings but I only get flashing lights. Is it finished? or is there another move or change I can make to get a steady light? This detector is about 5 years old. I flipped the photo. Thanks for all your help!
Once those motion sensors get internally wet they're pretty much doomed.
Lamp mode: normal-soft-flash.
Not sure what flash would be used for but that sounds like the mode that unit is stuck in.
Raemarti
voted this post useful.
Thank you. This motion detector is under good cover, about a 4 foot eve from the roof line. Nice deep eve. We have had a lot of rain though. Yes, thinking it is stuck....and in flash mode of all toggles and in broad daylight. lol I will test all positions again and turn the sensor in every directions. Then give it a healthy whack one last time and then replace it. Bummer. They are probably twice as much as they were before....ugh. I thought maybe someone had a trick for the flash part. Thank you all!
I don't have a trick for you, just my story.
I had an identical motion sensor floodlight die a couple years ago. I decided to replace it with a camera-equipped WiFi capable one and am really happy that I did. The LEDs are brighter than the old bulb and it's much easier to control via WiFi than the old mechanical switches. Plus it can optionally notify my phone, on a schedule, when it detects motion and send live video.
I liked moving into the 21st century so much I replaced my other, still working, motion light with the same thing.
Raemarti
My only suggestion is to work the switches back and forth a few times. I'm sure they are 2-cent switches, and after a few years. they can get corroded. switching them a few times might clear off some of the rust/corrosion and ensure they are in the correct position.
Raemarti
