Recessed light cut out
Old 02-11-23, 10:48 AM
G
Gen
Gen is offline
Received 18 Upvotes on 13 Posts
Recently I was cutting a 6" hole for a recessed LED disk. It was through 2 layers of 5/8" drywall, and I used a multi tool--my preferred tool as I don't have the hole saw.
Seems you have to push the blade straight edge (or angle it slightly) while plunging into the ceiling in a circular motion. For me hard to do accurately. I had a few minor glitches outside the circular hole.
Is there a better way with the multi tool on a circular hole? Or was It just more challenging with having 2 drywall layers? My thought was having a blade that had a cutting edge on 2 sides rather than one. But I don't see such a blade online.
Old 02-11-23, 12:21 PM
Received 4,154 Upvotes on 3,730 Posts
I wouldn't pick an oscillating saw as the easiest tool to use for that job.
They do make a blade that should make it easier.
I've never used it before......... Jab saw blade
Old 02-11-23, 02:03 PM
G
Gen
Gen is offline
Thanks Pete. I just ordered these. If not a hole saw or hand held jab saw, what would your tool of choice be for ceiling drywall holes?
Old 02-11-23, 02:18 PM
I use hole saws.
I also use a handheld keyhole saw.
The hole saw is by far the best method as the hole comes out perfect but it makes a dust mess.
I'll usually have a second guy hold the vacuum near to grab the dust.
Many people use a ceiling light cutter. It's..... ok.
Contains dust well but is a little tough to control.
The center hole enlarges quickly but would work great with double sheetrock.
Klein ceiling light cutter
Old 02-11-23, 10:41 PM
A
Received 176 Upvotes on 145 Posts
I've used this drill attachment. It's adjustable and easy to use. The plastic cup around it is only to catch the dust. you don't need to use it.
Old 02-12-23, 05:10 AM
Tolyn Ironhand's Avatar
Received 916 Upvotes on 774 Posts
I always just use a drywall jab saw. Hole saws or similar tools can wobble and make the hole too large and make a HUGE mess.
Two layers of drywall does make it more difficult so it helps to have a sharp saw.
