ski-doo engine problem
Old 01-04-16, 04:56 PM
D
my 1988 citation LSE is having running problems. the rubber boot coming from the air filter going to the carbeurator is leaking gas out of it what could the cause be?
Old 02-10-16, 12:30 PM
D
this morning I went to drive my citation and it started then after one second it quit and I think it could be something to do with the coil plz correct me if I'm wrong and tell me what the real problem(s) could be.
Old 02-10-16, 06:40 PM
G
Received 2 Upvotes on 2 Posts
Looks like a month ago you had a flooding carb problem. What did you do to fix it?
Your latest problem could be electrical. Start by checking fuses and then work your way though the wiring system, checking for a voltage loss.
Have you checked to see that the spark plug wire was firmly connected at each end?
