1996 EZGO cart won't go
Old 04-06-16, 06:56 PM
W
I have a 96 ezgo have 37.5 at both sides of solenoid and 37.5 at motor but no ground
Separated from... http://www.doityourself.com/forum/mo...l-not-run.html
Old 04-06-16, 09:33 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
Any model number ???
The positive is supplied to the motor thru the solenoid. So that tells you the solenoid is working. The negative to the motor is variable from the speed controller.
Old 04-07-16, 05:16 AM
P
Received 625 Votes on 578 Posts
How are you measuring voltage if you do not have a ground? How do you know you don't have a ground? Have you checked all your ground connections and cables?
