Golf cart problem
Received 0 Votes
Golf cart problem
My Yamaha golf cart starts great in neutral, but when I start it in drive in bounces dwon the road for 20 feet before kicking. It then kicks in and drives normally. Any suggestions would be appreciated. Thanks
Welcome to the forums.
I don't know the unit but why wouldn't you just start it in neutral ?
A year and model would be very helpful too.
Also, golf carts do not have neutral. The transmission only has forward and reverse. All shifting is done when the engine is not turning. Starting the cart with the shift lever between gears can damage the transmission if the input shaft is turning when you drop it into gear.
