Scooter Tire Question
Old 12-11-19, 05:37 PM
6
Getting a 1994 Honda Elite scooter, needs a new rear tire.
What is best, put an inner tube in or just go tubeless?
Thanks
Old 12-12-19, 04:51 AM
P
Received 2,180 Upvotes on 1,950 Posts
You said you need a new tire... so, you need a new tire. Is tubless an option with your rim? Putting a tube in the old tire probably is not a good option if "you need a new tire". If it were a relatively new tire but had a puncture I'd consider a tube but if the tire is old and needs replacing... replace it. Tubeless is probably less expensive since you don't also need to buy a tube.
Norm201 voted this post useful.
Old 12-12-19, 10:32 AM
T
Received 110 Upvotes on 98 Posts
Rims for tubbed tires have a hole for the valve, while tubeless tire rims have no hole. There are kits available to convert a tubed tire rim to tubeless by plugging up the hole although I'm not a fan. But converting from tubeless to tubed would require a new rim.
Unless I'm missing something.
Old 12-12-19, 10:41 AM
T
Beyond what I said before, if your scooter is in otherwise good shape or you want to restore it, you'll be best off to keep everything OEM.
