Can i use warm water in my power washer?
Old 03-12-16, 04:38 PM
B
Received 1 Vote on 1 Post
I saw an ad on a bulletin board downtown, This average sized company that power washes everything..says they can do this. The directions in the 3000psi power washer i bought from Sears! says; Don't use hot water in this machine.:NO NO NO: Mines good for cold water. Has anybody here ever questioned this idea/ bob s and thank you
Old 03-12-16, 04:43 PM
Received 82 Votes on 77 Posts
If the manufactuer says no then I would not do it, if it takes out the pump it will cost almost as much to replace it as a new pressure washer.
Why do you think you need to use hot water?
Old 03-12-16, 04:46 PM
C
Received 2 Votes on 2 Posts
You can buy pressure washers designed for hot water, but they are a lot more expensive than typical consumer models, which have pumps that depend on cold water to keep them cool enough to avoid destroying the seals in the pump.
Old 03-12-16, 04:57 PM
B
thanks for the info guys.Hot water cleans much better than cold its a fact of life. I will just have to get a longer handled scrub brush ...and some better soap! bob s thanks
