Honda HRA214 Self Propel not working
Old 06-21-16, 07:45 AM
I am working on a Honda HRA214 mower. The self propel has stopped working. This model has the driveshaft from the engine ot the transmission. With the engine running, I can see the engine side of the driveshaft turning. How can I tell if the driveshaft is any good or not. Also, how far should the self propel cable move when you pull the lever up. Can I determine if the cable is bad without removing the shield under the mower.
Old 06-21-16, 08:33 PM
cheese's Avatar
Received 50 Votes on 45 Posts
It's been a while since I worked on one like that. I think the cable should be moving 3/4" or and inch. I think you'll need to see the other end of tha cable and see if it's moving or not to know if it's good or not. I'm not even sure many parts are available for these anymore.
Old 06-22-16, 03:52 AM
cheese - thank you for the response. How can I tell if the driveshaft is good.
Old 06-22-16, 11:58 AM
cheese's Avatar
I guess you'd have to look at it and see if it's broken or not. I mean, a driveshaft isn't something that goes bad. Where it connects to the engine and transmission is more where you want to check. If it's turning, then the connection at the engine is good. Check where it connects to the trans and see. While you're in there, check the cable operation.
Old 06-22-16, 06:01 PM
I regret to say that I am calling the owner and asking him to take the mower to a Honda dealer. The driveshaft is $70 and the cable is so hidden under the shroud which I cannot get off. Thanks everyone for your help.
