Testing John Deere riding mower solenoid
Old 07-06-16, 10:31 PM
W
I looked at a couple of 4 post solenoids online, but the ones I see a ground was connected to one of the spade connectors and the ignition to the other. In the solenoid below (link), both spades are connected to the ignition switch. If I wanted to test this particular solenoid, would I just connect a ground to the mounting frame, then 12V to either of the spade connectors? Why are there 2 spade connectors on this solenoid? Assuming I connect my positive and negative correctly, I realize I should test for continuity between the 2 posts (or perhaps hear the switch).
Thank you.
https://solenoidwh.shutterfly.com/pictures/9
Old 07-06-16, 11:49 PM
Received 1,203 Votes on 1,113 Posts
The two spade terminals need 12vdc to be applied to make the relay close.
Normally one terminal goes to ground or even thru a safety switch to ground.
The other terminal needs positive and usually gets it from the momentary switch on the ignition that closes when the key is held to start.
The two large terminals are the battery supply to the starter and are shorted together with 12v on the coil terminals.
Old 07-06-16, 11:51 PM
cheese's Avatar
Received 46 Votes on 41 Posts
There are two spade terminals because this one is externally grounded instead of grounding through the mounting bracket. any Deeres control the ground to the solenoid through the safety system to keep it from starting with the blades on, etc...
To test, put 12 volts on one spade terminal and ground the other. When you do, it should click and you should get continuity between the two large posts.
Old 07-07-16, 06:36 AM
W
Thanks for the responses. I'll give it a try this afternoon.
