Briggs crankshaft diameter
Old 11-15-16, 03:05 PM
If anyone has a Briggs spec sheet and can tell me crank diameter on a 15A114 0342 E1 it would be greatly appreciated
Old 11-15-16, 03:22 PM
BFHFixit's Avatar
If you are asking about the output shaft, it should be 7/8" I believe.
What is it on? going on? coming off of...etc?
Old 11-15-16, 03:26 PM
Sorry I thought the purpose of the forum was to help each other out sorry for the bother
Old 11-15-16, 03:29 PM
BFHFixit's Avatar
I just asked for a bit more specific info...the IPL does not give dimensions and it depends on what diameter of the crank you are referring to...main journal, rod journal, output shaft, tapered end...???
Old 11-15-16, 03:52 PM
cheese's Avatar
Received 152 Upvotes on 139 Posts
The shaft is 3/4" and is 2 3/8" long.
Joe, why the condescending remarks to members? Why does anyone come here for info when they could just as easily go somewhere else? The only reason for them to feel the need to go somewhere else is to avoid attitudes like yours.
