Tecumseh leaf vacuum leaking oil
Old 12-03-16, 09:40 PM
D
My Tecumseh leaf vacuum is leaking oil from the base of the oil filler tube. Can I just use gasket sealer to stop it?
Old 12-04-16, 12:12 AM
cheese's Avatar
Received 54 Votes on 49 Posts
Yeah, you can pull it out and put some sealant on it without hurting anything. It's just a rubber gasket that is easy to replace (the sealant probably won't last that long).
Old 12-04-16, 05:10 AM
D
I'd rather do it right. Any suggestions on where to get the gasket or a manual or something? I haven't had much luck finding stuff on it.
Old 12-04-16, 11:13 AM
cheese's Avatar
36832 is the part number for the common one. I don't know what engine you have but this is likely what you need.
Old 12-04-16, 02:08 PM
D
Thank you. Where did you find it?
Old 12-04-16, 03:08 PM
D
Ok found it. Didn't realize that this is a documented issue with this model. At least it's a pretty standard part. How hard is it too replace? Are there instructions out there?
Old 12-04-16, 07:49 PM
cheese's Avatar
You just take the dipstick tube off, should be one screw, and pull off the old rubber ring and put the new one on and stick it back in place. 5 minute job if you take a break halfway through.
Old 12-05-16, 03:34 AM
D
Ok. I saw the screw but didn't know if there was more to it, like draining the oil or something.
Old 12-05-16, 05:03 PM
cheese's Avatar
No, the oil level is below the hole.
