Can I use Castrol GTX 5w-30 in my Craftsman snowblower?
Old 12-31-16, 08:38 PM
B
I'm new to yard equipment and also snowblowers. Last year I bought a Craftsman 24 inch, 2 stage, 208cc snowblower. I have never changed the oil in the first season and have used it now once this season. I know, that's most likely not a good thing, but I'm new to all of this and I just read you should change it after the first 5 hours. Luckily, I may not have too much over that time of use with it, but of course now it's time to change the oil!
So, after a little research on the internet I found out that you can use just regular car oil in a snowblower (5w-30?). Am I right? So, tonight I went out to Wally and bought 3 bottles of Castrol GTX 5w-30 motor oil, being of course naive and didn't realize that I only need 1 quart!
So is Castrol GTX ok to use? My owners manual says something about meeting SG and SF certifications, but I'm not sure I see those on the bottle. What does that mean?
Thanks
Hopefully tomorrow I can change my oil!!
Old 01-01-17, 02:22 AM
cheese's Avatar
Received 45 Votes on 40 Posts
If 5w-30 is the specified weight of oil that is recommended for your engine, then yes, you can use that to change the oil.
Old 01-01-17, 03:59 AM
T
Received 30 Votes on 28 Posts
Brian, in #W-30, the 30 represents viscosity at normal operating temperature so any "30 weight" oil will be the same when the engine is warm. The W is "Winter" viscosity or how well the oil flows in cold weather. That is, how easily it starts or turns-over before the engine (and oil) gets warm. 5W is safe to -22F so you should be fine. For your mower, use 10W-30. For equipment where you mix oil and gas, use 2-stage oil - non-marine.
One last point, if you keep the snowblower in a place where temps get below -22F, consider 0W-30.
Old 01-01-17, 05:09 AM
Received 77 Votes on 72 Posts
Make sure the engines warmed up before changing, or more of the old oil will be left behind.
Make 100% sure not to overfill it, that can damage the engine.
Smaller HP engines may not even take a full Qt.
Remove the dipstick if there is one or the full cap while draining so it does not form a vacuum when draining.
Old 01-01-17, 10:41 AM
W
Received 19 Votes on 18 Posts
API Code
API Engine Oil Classification
Look at the "donut" under the blue Mustang on the right side of the photo.
Old 01-01-17, 05:18 PM
B
Wow good thing I changed the oil! It was BLACK! I've only used it a little last winter plus one storm this winter. I used Castrol 5w-30 and it's now running great!
I think I'm gonna keep up on my maintenance from now on!
Thanks
