Tips for preventing trimmings buildup underneath mower deck?
Old 04-27-17, 09:12 PM
R
The grass is very wet this year and I am having to stop mowing often to clear the trimmings adhering to the underside of the mower deck because the engine begins to labor. Is there any way to minimize this?
Old 04-27-17, 09:31 PM
chandler's Avatar
Cut it more often, raise your blade height, and don't cut wet grass.
Old 04-28-17, 12:37 AM
Gunguy45's Avatar
Super Moderator
And don't do like my old neighbor. He would putt around with the engine barely above idle. He said he didn't want to go fast and didn't want to stress the transmission by upping the rpm and letting the hydrostatic drive do what it was designed to do. So he'd fully engage the drive and adjust speed with the throttle. That meant his blades were not turning at the optimal speed.
Old 04-28-17, 04:14 AM
chandler's Avatar
Good point. My Kubota ZD21 stipulates it works best WAO, so don't skimp on power.
Old 04-28-17, 05:01 AM
.... and be sure to clean the underside of the deck after you are done mowing. Dried clumps of grass under the deck will reduce the effectiveness of the mower and accelerate rust/rot.
Old 04-28-17, 05:09 AM
V
I may not be the most orthodox environmentalist; but every time I change the engine oil, I also remove the Deck, clean it, dry it, and then slosh on a coating of the used crank case oil around on the underside to impede rust, and to make it a bit more resistant to accumulating a build-up of grass clippings.
Old 04-28-17, 05:31 AM
If I have the time and feeling froggy, I'll repaint the underside of the deck on my push mower when I change the oil and sharpen the blade. I would have thought the grass would stick to the used engine oil.
Old 04-28-17, 06:14 AM
B
After cleaning I spray it with WD-40, grass doesn't seem to stick near as much and easier to get off later.
Old 04-28-17, 12:09 PM
cheese's Avatar
Mo-deck spray works. Best to mow dry grass but some grass holds a lot of water in it's cell structure like winter rye and some fescues and it's wet even when it's dry. If the klift portion of your blade is worn down, it will cause more sticking. If the RPM is too low, or the chute is not open, it will also cause poor ejection of clippings.
Old 04-28-17, 03:50 PM
Sometimes I sit it on concrete and run water under the mower with rpms up. The mower sucks the water up off the concrete and washes the deck underside. Works pretty good right after a mowing.
Old 04-28-17, 05:51 PM
Marq1's Avatar
Ok so what is WAO, wide ass open?
Old 04-28-17, 07:27 PM
BFHFixit's Avatar
Most normally stated as WOT (Wide Open Throttle) however you say it, firewall the juice :Peeping On U2:
