2007 Craftsman DLS 3500 mower brake adjustment
Old 08-19-17, 09:56 AM
L
Exclamation 2007 Craftsman DLS 3500 mower brake adjustment
I have just replaced the pads on the above mentioned mower and still do not have brakes. I have adjusted the middle nut on the caliper, which used to give some brakes, but now it doesn't help. Is there another adjustment I can make to be able to cut grass safely? Please help!
Old 08-19-17, 11:34 AM
cheese's Avatar
Received 45 Votes on 40 Posts
Are the plungers in the brake moving back and forth freely? If it was working before, then that nut is the only adjustment you should have to use. I wonder if your new pads are thinner than the old?
Old 08-19-17, 04:19 PM
L
The pads are about the same thickness, only the surface was rougher on the new ones. I didn't check the plungers. I have seen other videos that showed an adjustable spring, but this mower doesn't have that as far as I know. I'll check to see if the plungers are working. If they are working what would be the next step?
Old 08-20-17, 12:45 PM
cheese's Avatar
If the pads are the same thickness as the ones that were worn out and not working, then it sounds like they are the wrong ones. Did you use your model number to find the pads?
Old 08-27-17, 07:23 AM
L
I had just picked some at the local parts house, what they had in stock. They were not the right ones for my mower. I didn't realize they could order exactly what I needed, but they advised they should be able to get what I needed. So, I had them ordered. I had looked around online and couldn't find the pads. But anyway hopefully these will work.
