Craftsman 29/10 snowblower
Old 09-04-17, 07:32 AM
Snowblower craftsman29/10 will not move forward or reverse, changed friction wheel and still no movement Help
Old 09-29-17, 03:11 PM
Received 1 Upvote on 1 Post
You have to tilt it up and take off the bottom cover, then look at every thing that is in the drive chain [mechinism ] to see what is not moving when you turn the rubber disc wheel, some thing is not moving between the disc and the tires. Or maybe the disc is not touching the drive plate.
Sid
Old 09-29-17, 06:48 PM
Received 3,749 Upvotes on 3,362 Posts
Welcome to the forums.
What is a 29/10 snowblower ?
A Craftsman model number will be xxx.xxxxxxxx
Old 10-07-17, 05:35 PM
Sidny
Thank for the feedback, I tried everything And realized after pulling the chains out which I had to do and the gears with it , that the housing had broken off in two spots where the smaller shaft holds the smaller gear and the housing had to be welded in two spots little complicated to describe but finally got it togetherness running
