Echo leaf blower not starting
Old 11-12-17, 05:48 PM
P
Echo ES-255 Leaf Blower
I replaced both the carburetor and spark plug on my leaf blower with new ones. I have also confirmed ignition system is functioning with inline spark tester. Unit will start with difficulty with choke active, but will stop when switched to run.
It appears to be fuel related with fuel not reaching the engine, but with a new carburetor installed I am baffled.
Any suggestions?
Thanks
Old 11-12-17, 08:34 PM
G
While the unit is running spray/dribble carb/brake parts cleaner behind the carb and along all mating surfaces if the engine tempo changes you have an air leak otherwise the fuel lines and filter need to be replaced. Have a good one Geo
Old 11-12-17, 09:37 PM
P
Thanks for reply, I'll check tomorrow. Fuels lines are new, air filter is new and also for and aft carburetor gaskets. New fuel filter also and new breather. All parts are new including the spark plug.
Old 11-13-17, 04:47 AM
B
U don't say the running condition before U changed all the parts. It would be helpful. Older Echo's had a spark arrester (SS screen) that caused poor performance when dirty. The muffler had to be removed to clean it.
Old 11-13-17, 05:21 AM
My guess would be that the flywheel key is sheared or partially sheared. I have replaced a couple on Echo PB-150 blowers. The key is integrated into the flywheel.
Old 11-13-17, 12:30 PM
cheese's Avatar
What was it doing before all this? Why did you replace these parts? Have you checked compression?
