Carburetor ID
Old 12-15-17, 01:03 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Carburetor ID
Hi All, can anyone ID this carb,it has been painted over so I can't find any numbers, it also is not on the engine it was designed for.
Geo
Last edited by Geochurchi; 12-15-17 at 01:51 PM. Reason: reoriented/enlarged/enhanced picture
Old 12-15-17, 01:52 PM
Geochurchi's Avatar
Thanks Pete...................................
Old 12-15-17, 02:10 PM
A
Received 124 Upvotes on 107 Posts
what are you working on exactly how old is it looks kinda like a zenith 267 but would probably try looking better for some numbers or name on it.
Old 12-15-17, 08:12 PM
cheese's Avatar
Received 148 Upvotes on 136 Posts
It's an old Briggs and Stratton updraft carburetor. Looks like maybe the throttle hookup has been modified.
Might check these and see which one is the best match and use that info
https://www.google.com/search?biw=10...76.3239hY_Idug
Old 12-16-17, 05:28 AM
Geochurchi's Avatar
Thanks Cheese,I think I found it, it definetly has been modified this is setup on a Fairbanks Morse 1 1/2 HP stationary engine,everyone says it ran at one time,I am trying to figure out how to do the basic adjustment ,I pulled it apart and everything is clean inside.
Geo
Old 12-16-17, 11:50 AM
cheese's Avatar
The adjustment under the carb is the high speed mixture screw. The one near the mounting flange is the low speed mixture screw. Normally best set at 1 1/2 to 2 turns out from lightly seated.
Old 12-16-17, 01:23 PM
Geochurchi's Avatar
Got it!! Thanks,I'll post a pic of the engine it's on at some point.
Geo
Old 12-20-17, 01:29 PM
Geochurchi's Avatar
HI All, any ideas how I can find a repair kit for this carb? Don't know what engine it came off of and I can't see any numbers on the carb itself, I have found pics of it online.
Geo
Old 12-20-17, 03:12 PM
BFHFixit's Avatar
The name flojet comes to mind.....kinda like what used to be on some old front tine tillers, 5HP horizontal...
If its the same that emulsion tube runs up at an angle to the top part of the body and has to come out before separating. Was really bad about galling the threads and not being able to get it out.
Old 12-20-17, 08:09 PM
cheese's Avatar
Look at Briggs part number 291691 and see if that looks like the one you need. It's hard to judge the size of this carb from a picture, but it looks like the carb that would use this kit.
Like BFH said, the emulsion tube can be very hard to get out, or it may come out no problem. Use a straight screwdriver that is as wide as possible without scraping the sides of the hole. Be sure it's straight sided, not tapered like most screwdrivers. Make sure the tip of the screwdriver is in perfect condition, regrind it if necessary, and put the carb in a vise so that you can put a lot of pressure on the screwdriver to keep it engaged. Spray PBlaster in the hole liberally. It may try to shave the brass slot off the jet so that it can't be removed. If you get any hint of this happening, stop. Get an impact driver (the kind of screwdriver that you hit with a hammer and it turns when you hit it). I have also dripped acid into the hole to clean out corrosion to allow the jet to come loose and unscrew. Don't let the acid stay too long or it will eat the threads out of the hole.
Old 01-10-18, 03:42 PM
Geochurchi's Avatar
Rebuild kit
Hi All, I received the suggested rebuild kit and everything looks the same except for the inlet needle valve is metal instead of plastic, and attachment is different, will this still work?
Old 01-10-18, 10:10 PM
cheese's Avatar
Wish I could tell you, I haven't had to rebuild one of those in a long long time.
Old 01-11-18, 04:56 AM
Geochurchi's Avatar
After a closer look I noticed that the needle valve has a rubber ,or what ever, on the tip so it maybe alright I was worried about not having that grooved seal in the bottom of the the inlet,
Geo
Old 01-11-18, 11:44 AM
Geochurchi's Avatar
Carb rebuild
Hi All, anyone know if there should be a spring on this needle valve,seems to fit loosely, also I think this cork gasket is not needed as top gasket dose the same function.
Any thoughts?
Old 01-11-18, 03:27 PM
BFHFixit's Avatar
If you can get the model of the engine cheese used to find the part# you could see a breakdown.
I think one goes on each side the cork to the carb side...??? then the valve seals in the gaskets and provides resistance to hold adjustment....
