Tecumseh yard vac can't pull crank
Old 05-26-18, 08:38 PM
D
I've been using my tecumseh on my yard regularly, today I did a few loads and it won't crack. The pull cord got tighter and tighter and now it won't move at all. Did I seize the engine? If so, how do I fix it?
Old 05-27-18, 12:35 AM
cheese's Avatar
Received 46 Votes on 41 Posts
Is it out of oil?
_________________
Old 05-27-18, 04:41 AM
D
It's low but not out as far as I can tell.
Old 05-27-18, 05:09 AM
P
Received 681 Votes on 628 Posts
Does it feel like the pull cord is somehow bound up or do you think it's the engine? Try removing the spark plug and try pulling the starter cord.
Old 05-27-18, 05:44 AM
Geochurchi's Avatar
Received 78 Votes on 73 Posts
What model engine are we working with here? I might pull the spark plug out and put some oil into the cylcinder and see if the piston will loosen up a bit,even some Mystery Oil might work, be sure to drain the oil after .
Geo
Old 05-27-18, 06:47 AM
D
I think it's the craftsman 247.770110 from the manual.
Old 05-27-18, 07:04 AM
Geochurchi's Avatar
Thatís not the engine model number, it should be stamped on the engine itself.
Geo
Old 05-27-18, 07:44 AM
D
It says engine model 143.004500 on the side. Under that, engine family ytpxs.1951bb
Old 05-27-18, 01:07 PM
cheese's Avatar
How low? Barely touching the stick? I have a feeling it is locked up but since it did it while cranking, maybe you can salvage it by adding oil to the spark plug hole as mentioned and then take the cover off so that you can rotate the engine by the flywheel and see if you can make it turn. It's also possible that something is wedged in the fan side of the unit. Usually if a tecumseh runs low enough on oil that it has this kind of problem, it's not long before there's a hole in the side of the block.
Old 05-27-18, 06:30 PM
2
Received 2 Votes on 2 Posts
follow cheese's suggestion. I had this happen last year and a little stick got wedged between the flywheel and the housing. While you have it apart, do all your normal maintenance and check the recoil system while your at it.
Old 05-27-18, 07:17 PM
D
Cool. How do I get to it? I thought I took the three bolts of but didn't work.
Old 05-27-18, 07:49 PM
D
Oh, dumb questionbut how do you drain the oil?
Old 05-27-18, 10:20 PM
2
The drain plug should be under the deck. I had to take the plastic cowling off and the recoil and that's where I found the stick wedged.
Old 05-28-18, 02:56 AM
cheese's Avatar
There's no "deck" on a yard vac. The drain plug is at the base of the engine.
Old 05-28-18, 05:19 AM
D
Can you give me an idea of where it is cheese? I'm looking but i don't see it. Is it that Alan slot beside the oil?
Old 05-28-18, 05:51 AM
Geochurchi's Avatar
Hi, check this link out, but turn the machine on itís side and drain oil out of the fill tube.
https://www.searspartsdirect.com/par...n-parts-manual
Geo🇺🇸
Old 05-28-18, 09:43 AM
D
Ok, the liquid wrench and some choke cleaner managed to get the piston unstuck. It coughed out a bunch of carbon and then smoked like crazy but now it works great again. Thanks.
