Snapper Rear Engine Rider
Old 05-30-18, 11:57 PM
I
Snapper rear engine rider. Model 301123BVE
The disc drive part number is 84875 which I cannot find. Many of the sites I've checked will show they have it. But when I look inside. i can't find it. Seems to be plenty of disc drives with part # 7084875. Will the latter work?
Thanks in advance.
Old 05-31-18, 11:04 AM
cheese's Avatar
Received 48 Votes on 43 Posts
Yes, it's the same part. Snapper numbers recently got the addition of 70 in front of them, and many have YP at the end as well. It doesn't change anything as long as the rest of the number is the same.
Old 05-31-18, 02:08 PM
I
Thanks so much for your reply. Yes i knew that but typed the wrong number. The real question is, will 10765 work? Also, I get lured into sites stating they have my part #. But once inside they all show numbers like 7070xx xxx and such . They look like what I need. But may be for smaller mowers? I've never had spent this much time looking for any kind of part. Seems crazy to me.
Regards Bobby
Old 06-01-18, 12:30 AM
cheese's Avatar
84875 is a model for the entire mower, not a part number for a drive disc.
The drive disc is the big metal disk that bolts to the bottom of the engine. The driven disc is the rubber wheel bolted to the rear end. 10765 is a driven disc, so which do you need? 10765 fits some mowers but the disc you need is part number 7600135YP if the driven disc is indeed what you're after and your model number is correct. This disc has a liner in it designed to slip and allow a smoother engagement. The other disc does not and it won't work with your rear end.
