Murray 30” riding mower blade drive broken
Old 06-26-18, 02:20 PM
D
I have a older 30” Murray small riding lawn mower that runs great. The shaft broke in 2 places that turns the blade at the pulley wheel and at the blade shaft underneath the mower. So the blade won’t turn anymore and the blade shaft is completely broken in 2 places
Is it worth it to try to repair this or will it be too costly?
Old 06-26-18, 03:15 PM
V
Received 2 Upvotes on 2 Posts
Is the broken part(s) something like this ?
Old 06-26-18, 03:48 PM
D
Yes it is broken where the shaft meets the pully, it is also broken where the blade meets the deck underneath the bottom, cracked there too. is it worth fixing?
Old 06-26-18, 03:59 PM
D
Received 227 Upvotes on 179 Posts
Not worth fixing but you can buy a new one & replace it. Just have to find the part number or just search for your mower parts & get a price. They're usually not that bad. Cheaper than another mower.
Old 06-26-18, 04:04 PM
V
These Spindles (Quill Assemblies) are available on eBay for the most common Murray Ancestors and Descendants (AMF, Dynamark, TurfMaster, AYP, Murray, Noma, among others) . . . . I keep an old 1973 AMF running because the basic design had staying power and the parts were very very popular. These Quill Assemblies can be had for $25 to $35 apiece after shopping around.
If you post your Murray Model Number, either I or someone else may be able to locate the appropriate part. A 30" Deck sound like it was only one blade or two small 15" blades. Until recently, I would say they didn't make anything that small . . . . but I had a 30" Chain Driven Country Squire Rider sitting around here for awhile; so that proves that MTD (another family) saw fit to make such a size.
What was/is the Murray Model Number ?
Old 06-26-18, 04:17 PM
D
I wish I could locate the model #. The sticker is worn off. It is a Murray 30” with a 10hp motor. I’m guessing 2005 around there. The guy I bought it from replaced the motor with a 13.5hp around 2010.
id sure love to fix it. It has the rear bag system and probably $1200 to replace it
Old 06-27-18, 12:38 AM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Old 06-27-18, 03:00 AM
V
Originally Posted by danrud
". . . I wish I could locate the model #. The sticker is worn off. . ."
The Model and Serial Numbers are typically located in places that are NOT subject to any wear; like under/behind the seat on the Chassis.
Because it's so young, and Walmart is still selling a similar model, it may pay to go look at a new one and see where the Model Number is located . . . . or call the Manufacturer (which is now Briggs & Stratton.
Having the correct Model Number takes the guesswork out of the whole deal.
Old 06-27-18, 07:42 PM
D
Yes that makes sense I will locate it so I make sure to get the right part
Old 06-28-18, 03:47 AM
V
Murray made dozens of 30" Rear Engine Riding Mowers under its own name and that of others (Mills, Walmart, Western Auto, etc) in 2005 . . . . but here's one of them which may give you some help (if it's at all similar to yours, in identifying what exactly has broken:
http://https://www.partstree.com/parts/murray/mowers-rear-engine-riding-lawn-mower/309008x99a-briggs-murray-30-mid-engine-rider-2005-aafes/mower-housing/
You usually only want to purchase the pieces that are worn/broken (if possible). Partstree is a good place to get Part Numbers; then you can go shopping for the right thing where ever you can find it !
