Craftsman 50 cc chainsaw blade cover issue
Old 06-12-19, 12:48 PM
R
I have a craftsman 50 c.f. chainsaw that I removed the blade cap (?) to do some cleaning. I released the tension on the chain then unscrewed the two nuts to remove the cover. The cover should have come off smoothly, but didn't. Now that the cover is off, it won't go back in completely as it should. When I start the chainsaw, it's making smoke. I don't see what the problem is. Nothing is broken. Maybe the clutch assembly changed position?
Old 06-12-19, 12:57 PM
Received 1,193 Votes on 1,104 Posts
Welcome to the forums.
I moved you to the proper forum and started a new thread for you.
Old 06-12-19, 01:39 PM
cheese's Avatar
Received 46 Votes on 41 Posts
Most likely the clutch drum brake band got engaged during removal or before removal (hence difficult removal). I'd reset the brake bar and see if it goes on properly.
