Shaft and pump on a power washer.
I have a Excell 2500 power washer and the Honda
GC 160 5hp engine head cracked. I was going to replace the engine with a Predator engine from HF but the shaft is 3/4" in diameter and 2.43" long and the pump hub is 7/8" at first and than tapers down to 3/4". Is there an adapter that I can use to connect the two?
