Yard machine idling up and down
Old 08-18-19, 03:09 PM
A
Any help is appreciated!
I have a yard machine push mower. Briggs and Stratton engine.
First the mower wouldn’t start. I replaced the fuel, cleaned the carburetor, air filter. Now the mower will start but idles up and down for a min or so then shuts off.
I have a video but don’t know how to attach it 😐
Old 08-18-19, 03:26 PM
Received 12 Votes on 12 Posts
Hi Amy:
Sounds like a lean fuel mixture. The condition is called hunting.
Two most common causes for what you've described are loose carb mounting bolts, air leakage at gaskets, dirty carburetor.
Spray some WD40 around the carburetor while it's running to see if rpms change.
Add a little Sea Foam to the fuel. Double dose it until it clears up, then adjust the mixture of SF/gas per instructions on can.
Old 08-18-19, 04:48 PM
cheese's Avatar
Received 45 Votes on 40 Posts
Agreed, not enough fuel or too much air. For more detailed info, we need to know what you have.
