Topflite 5/24 parts
Topflite 5/24 parts
I have a top flite 5/24 . I have read here it was made by MTD for K Mart. Model # 310-600-120/H279B I am looking for a parts diagram and manual for it . The drive works but the auger does not turn . The auger drive turns to the differential But the augers don't turn . I think it is the ring gear but don't know for sure . Trying to determine if the cost of parts availability and price make it work fixing . Also the tires are worn and should be replaced . Can a newer set of tires and rims , even though they may be taller be able to be fitted ? Thanks for any help
Top Flite
I am not sure, but I have heard that if you take your model numbers etc to Tractor Supply that they can get the parts you need for you. I would call the nearest one and see what they say.
