Tecumseh engine block: is it repairable? Costwise?
I have a Tecumseh engine block with a hole in it. I have the aluminum that fills between 95 to 98% of the hole. Where the hole is, creates some question about the block being repairable or cost effective. Part of the cylinder in the lower area is affected and where the lower crankcase pan attaches. If the aluminum were to be welded and additional aluminum added then grown down to make a matching surface that would allow the crankcase pan to fit right. Now to address the cylinder area. I thought if I get the cylinder area welded I would increase the cylinder bore by boring then put in a sleeve. Could a sleeve with the block welding overcome the lower cylinder weakening issues due to the damage? Would a sleeve cost way too much? How much cost would be involved in cleaning the block, and paying a skilled person to TIG weld? I have pictures that I can send.
joecaption
voted this post useful.
You are asking for opinions on cost and doables where the answers are determined by local weld/machine shops who can see the pieces. Some legwork is needed.You don't say what the engine is used for but personally I would just purchase a new short block. .
joecaption
