Craftsman tractor will not start
2017 Craftsman Lawn Tractor. Will turn over and gets fuel, but will not start.
Before buying anything I would remove the spark plug. Connect it to the spark plug wire and hold it so the tip or threads are touching bare metal of the engine case. Then try starting and see if you have spark.
If you have spark I would pour a teaspoon of gas into the cylinder and re-install the plug and wire. Then try starting. If it sputters, fires or runs for a second you have a fuel problem.
