Reading Standby Generator Oil Level
Old 09-07-22, 07:28 AM
G
Gen
Gen is offline
Received 16 Upvotes on 11 Posts
I have a 13kw standby Generac generator. It's very difficult to read the oil level after I change it--even with a magnifying glass--because it's so clear.
Can I use one of the dyes that I see available? How much should I use, and will it harm the engine? Thanks!
Old 09-07-22, 07:53 AM
P
Received 1,953 Upvotes on 1,749 Posts
Look up the oil capacity of the engine and measure the appropriate quantity of oil.
cheese voted this post useful.
Old 09-08-22, 06:06 PM
G
Gen
Gen is offline
Well It's 1.7 Gallons oil I need, and I can do the dye to oil ratio calculation.
The dye however only mentions "For all auto Oil and fuel systems." So my question is whether or not it's safe for a small Generac standby generator engine?
Old 09-09-22, 04:47 AM
P
Generally automotive oil specs exceed almost all others and there is no problem using a higher rated oil.
I have never used or had a need for dye. If I have trouble seeing the level I just touch the dipstick on a piece of paper or paper towel. When your remove the dipstick you can see the level by the oil left on the paper.
Old 10-03-22, 09:33 PM
Received 1 Upvote on 1 Post
That may be 1.7 quarts!
CircuitBreaker voted this post useful.
Old 10-03-22, 11:54 PM
Received 3,619 Upvotes on 3,245 Posts
Correct..... it is 1.7 quarts with filter change.
